werni9's avatar
werni9
Camco Ven Geri GENERATOR EXHAUST EXTENSION KIT
$133.00 for this kit.
I need to know what happens when it rains hard using the generator?
Has anyone owned one of these that would know?
Does the water settle in the elbow of the main exaust pipe?
Drilling a hole to let rain drain seems to defeat the purpose.
Could I use a 90 degree at the top?
  • The water will pass through and drop to the ground since there is no closure between the genturi and the exhaust pipe.
    Well for one thing, the heat from the genny evaporates the little water that MIGHT get in.
    Have had mine for 20 years and still works great, rain or shine!
  • Much to do about nothing. How much water do you think enters the pipe?
    There is not a solid connection between venturi piping and exhaust pipe, there is an air gap between the two.
    The negligible amout of water entering from the top will simply drain at the bottom
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 22, 2025
