silvercorvette
Jun 02, 2013Explorer
The first time I unhooked on this trip I stuck a large wood block cut at an angle on one side. I was a little nervous even though I was parked on a dry level asphalt surface. I had been using Rotochoks on my other RV and did not realize they would would not fit the newer RV with closer wheel spacing. I had the correct size ordered and waiting for me when I arrived in NY. When you consider the fact that thousands of dollars damage can occur due to inadequate choks spending a couple hundred dollars for protection instead of using plastic ones seems like a no-brainer. Get something like THIS or THESE ROTOCHOKS THAT I OWN, do not take the risk of using something cheap.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Apr 15, 2020
