- wbwoodExplorer
dee74 wrote:
I would just hook it up and pull it forward.
Ditto....you could of already done it by the time you came on here and asked the question. Don't make it any harder... - MrWizardModeratorIf you lift from under the axle...Yes
I would Not lift the camper from any where on the side rail frame
It's Not built for it
It will bend under the stress of trying to lift the weight at one point, especially if the tires are sinking and stuck - tegu69ExplorerYep. Be careful where you put the jack.
- bpoundsNomadYou only have to move it about 1 foot to get it up on boards. Cut two boards, each about 18" long. Pull trailer forward 1 foot. Place board behind rear tire, another board behind front tire. Back up 1' to same spot as before.
I don't know why folks insist on using a 5' long board for leveling. It's a lot more practical to use short lengths.
You can also just dig some shallow holes on the other side, since it looks like soft packed soil. Same thing. Pull forward 1 foot. Dig holes. Back up into holes. - K3WEExplorer
Kafn8td wrote:
If you can't jack it up, how would you change a flat tire?
Yes, but there are some wrong spots to jack on some trailers where things can get bent. - Mich_FExplorerSince it hasn't moved in 2 years and you want to take it to camp grounds, it seems to me that the smartest (and easiest) thing to do is hook it up, and pull it onto your boards. For all you know it might not even move. The brakes could be locked up, bearings frozen.
- Kafn8tdExplorerIf you can't jack it up, how would you change a flat tire?
- Jacking up a trailer isn't going to hurt it. If you had a flat while on the road you'd have to jack it up to replace the flat. Place the jack under the axle where the spring hanger is located. If you put the jack on the frame you'll have to extend your jack more because as you jack up the frame the axles will drop down until they limit their bottom movement. By placing the jack on the spring perch the axle will rise as you jack and you won't have to jack as much. To get both axles up jack up one, block it up, then jack up the other. Place your board under both tires and then repeat the process to lower.
- tegu69Explorer
K Charles wrote:
If you jack where the spring hooks to the axle what can it hurt? that's where the weight is when your driving down the road and where it's been for the last 2 years
If you are reluctant to move it right now, you could do this, but instead of putting one board under both tires, you could do one at a time. Or, wait until it dries out back there to do anything. - Community AlumniI jack mine up using a floor jack under the spring hangers block to re-level it if it settles in one spot. Quick to do and don't need to re-hitch and disconnect everything.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Dec 22, 2025
