- Happy_Camper3Explorer
Ivylog wrote:
I would raise the two jacks on the high side 1" and lower the two on the low side 1".
Last time I used the leveling jacks to try to raise and lower my camper, the front left completly busted off !
I then learned those are not for raising the camper, only stabilizing.
I may just pull forward, or jack under the axle, as long as the jack doesn't block where the wood would go..
As far as moving to level ground, that WAS the level ground, I'm in a tight spot, on my own property, I don't even have room to turn around, and moving to another spot would only be more muddy and worse.
this spot I am at now was prepped with class5 two years ago, and leveled the best I could before I put it there. - Water-BugExplorer II
djgarcia wrote:
Water-Bug wrote:
How old are the tires? Were they 5 years old before you parked it or brand new?
EDIT The tires should be stamped with a manufacture datecode.
There are 4 numbers on the side of the trailer. The first 2 numbers are the week the tire was mfg. and the last 2 numbers represent the year the tire was mfg. Any tire over 5 yrs. old, I throw away regardless of how the tire looks.
Those 4 numbers are on the TIRE, not the TRAILER. - ScottGNomadYou wont hurt a trailer that size by lifting it on one side by the frame.
- Winnebago_BobExplorer
dee74 wrote:
I would just hook it up and pull it forward.
^This..
Then do some research and figure out the age of your tires..
Are there visible cracks anywhere on the sidewall?
If it's been sitting two years without moving, how often did you check, service the tires?
Is one side of the trailer more exposed to the sun than the other? Those tires likely took more wear.
Not enough info to give reasonable advice on the tires, and I would definitely pull it forward to level it rather than jack it up unnecessarily. It would take all of five minutes with zero risk.
Press the easy button. - cyntdon2010Explorer
X2 this make good sense. - IvylogExplorer IIII would raise the two jacks on the high side 1" and lower the two on the low side 1".
- tegu69Explorer
or move it to level ground. - dee74ExplorerI would just hook it up and pull it forward.
- K_CharlesExplorerIf you jack where the spring hooks to the axle what can it hurt? that's where the weight is when your driving down the road and where it's been for the last 2 years
- MarkTwainExplorer
Looking for advice before your next adventure? Look no further.25,122 PostsLatest Activity: Apr 08, 2025
