myredracer
Apr 18, 2015Explorer II
Electrically either way will work but generally speaking, the fewer the plug/connector connections the better. My choice would be the 50-15 in the link. A dogbone adapter is also preferable over a puck style.
One thing you should do is always turn the power off before plugging in (either at source end of power cord or inside an RV) otherwise you can end up with pitting on the contacts and dirt buildup leading to overheating. Ensure plug blades are kept clean. Had two 15 amp extension cords go up in smoke in our driveway in a short period to time from failing to shut the power off. Now have a 30A recept. c/w disconnect in our carport.
Looking for advice before your next adventure? Look no further.25,197 PostsLatest Activity: May 21, 2026
