dee74's avatar
dee74
Can I use two power cord adapters together
I am in the process of purchasing a new tt that has a 50 amp power cord. I plan on buying a 50 amp to 30 amp adapter much like this one 50 to 30and I already own a 30 amp to 15 amp adapter much like this one 30 to 15 My question I have, is it safe to connect the adapters together or should I purchase a separate 50 amp to 15 amp adapter like this one 50 to 15 ?
  • Used a 50A to 30A and then a 30A to 15A plugged into house outlet for 2 weeks while we lived in RV alongside house during closing.
    Converter/charger, TV and A/C FAN in use.
    Was able to run 15K A/C unit but had to turn off converter and start a/C fan first.
  • No problem. When in storage I use a 50-30 adapter to a 30-15 adapter. Stays plugged in that way any time it is in storage. Very little load on it of course.
  • It is safe to use both adapters simultaneously. However you will be VERY limited in what electrical appliances you can use. I would limit my usage to battery charging and maybe a fan.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Dec 02, 2025
