darsben
Dec 21, 2013Explorer II
Get a small generator at harbor freight for less than 100 dollars and a battery charger to plug into the generator. Run the generator until you retire for the night (later if no one close to you) then the battery might last through the night.
If you connect to the tow vehicle you run the risk of not starting in the morning. This problem can be taken care of by the same outfit described above
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 16, 2026
