mowermech
Dec 22, 2013Explorer
dieselenthusiast wrote:
For this trip, we brought along our Mr. Heater which I believe is called the Dual Daddy????? It's suppose to be safe for indoor use and runs off two propane 1 lb. cylinders. This supplemental heat will maintain the inside temps helping reduce the amount of times the furnace kicks on. The Mr. Heater has an optional fan for efficiency, and it can run off D sized batteries.
That heater is safe for indoor use IF you read and follow the instructions! The instructions will tell you how much ventilation is required. DO NOT try to skimp on the ventilation! It would be better to have too much than not enough.
READ and FOLLOW the instructions!
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 11, 2026
