beeman1's avatar
beeman1
car dolly
Do I have register a car dolly?
  • If the dolly is doing 100mph and loaded with whacky tobacco you may get stopped, other than that I wouldn't worry. Been to 46 states so far and 55or60 thousand miles no problem.
  • vic46 wrote:
    tobydad wrote:
    I believe that in Massachusetts, as long as the car that is up on the dolly is registered, then the dolly does not need to be registered.
    And, no registered vehicle on the dolly?
    A dolly doesn't have to be registered w/ or w/o a vehicle on it.
    If there is a vehicle on it, the vehicle must be registered (or tow permit) If the vehicle on the dolly is not registered, the driver can be cited for towing an unregistered vehicle that has wheels in contact w/ the hiway.
  • Registration rules and procedures are VERY "State Specific".
    The only place you are going to get a valid answer is from the applicable State authorities in your state!
    While it does not do you any good at all, I can say that here in Montana a dolly does not need to be titled or registered. BUT, one can do so if desired.
  • I believe that in Massachusetts, as long as the car that is up on the dolly is registered, then the dolly does not need to be registered.
  • Most of the time a dolly is listed as equipment and does not require to be registered. We just purchased a ACME dolly and even though we do have a title it does not have to be registered here in NC.
  • DrewE's avatar
    DrewE
    Explorer III
    New hampshire does not require registration of tow dollies:
    Saf-C 504.13 Single Axle Tow Dolly.
    (a) Registration of single axle tow dollies shall not be required in this state.
    (b) For the purposes of this section, “single axle tow dolly” means a vehicle designed and used exclusively to transport another motor vehicle and upon which the front or rear wheels of the towed motor vehicle are mounted, while the other wheels of the towed motor vehicle remain in contact with the ground.
    Quoted from http://www.gencourt.state.nh.us/rules/state_agencies/saf-c500.html
  • Check with your DMV. They may or may not consider it a trailer.
