DrewE
Apr 30, 2015Explorer III
I would put the door on the outside so I have easier access. Possible exception: if having the door to the inside allows you to slide out a slide (temporarily) into the open area at the end, that could be a very handy advantage.
I don't think it makes any significant difference on the life of the RV; after all, one side is going to be a little more exposed regardless, so what you gain on one hand you lose on the other (and vice-versa the other way around). Maybe the excessively diligent would occasionally turn the rig around end for end to keep the UV exposure more or less equal...but not I.
Looking for advice before your next adventure? Look no further.25,195 PostsLatest Activity: Apr 08, 2026
