2chiefsRus wrote:
Toad Charge
This is what we use. Don't know how much a dealer would charge you to install it.
I installed it myself and didn't use the conductors in the existing umbilical cable because I wanted to make sure the wire I used was sized properly. I zip-tied the wire provided in the Toad Charge kit to the coiled Blue Ox umbilical cable so I can handle it as a single package.
As for installation, we have a DP so the battery bank is near the rear. It was actually pretty easy and I'm not the most mechanically inclined person.
As for the Toad Charge being too expensive, I didn't think the ~$80 to be a bad deal
Toad Charge. You get a circuit breaker (I don't believe the RVi kit includes this), a charge controller (that prevents the toad's battery from receiving charge unless the MH is running and also prevents backflow from the toad to the MH battery) plus all necessary wire and connectors.
From what I can see online t appears that the RVi kit assumes that power will flow to the toad through the existing umbilical rather than a separate wire. Some of the cables I've seen people use as umbilicals have conductors that are way too thin to handle any significant current flow. Remember, with ~40 feet of wire there can be significant voltage drop.
I'm sure I could have found all the pieces separately and saved a few bucks, but IMHO sometimes it's nice to have everything packaged for you. I didn't have to run to Home Depot even once during the installation!
