Motorhomes are designed to sit longer if needed without driving. If it was mine I might drive it once or twice a month, and of course the alternator will charge the engine battery even while parked and idling. But a more efficient means to charge the battery would be a plug-in trickle/float charger/maintainer as others have mentioned (as little as $10 at Harbor Freight) or a small solar trickle charger you can leave attached, the latter even more helpful in storage lots without electricity. You shouldn't need to drive an RV to charge the battery, there's better ways to do that. You can buy a $10 voltmeter at Harbor Freight to check voltage if needed, fully charged should be roughly 12.6 to 12.7 volts. As for frequent short drives, water condensation can accumulate in the motor oil without it being evaporated out, it becomes acidic and can lead to sludge and related lube issues over time.
