73guna's avatar
73guna
Checkout my home made slideout drip rails.
So, I had an issue with water getting in around the 13' main slide which caused minor damage to the plywood floor.
I traced the leak (at least I hope I did) back to the upper bulb seal and damaged mounting flange.
The slide would only leak when it was in the closed position.
I have three slides on the camper so I went ahead and replaced or repaired all nine bulb seals and caulked everything up nice and tight.
With the camper being stored outdoors and the slide retracted most of the time I decided it was best to keep the water from puddling on the top seals and to shed away from the slide and seals as much as possible.
I then had a local sheet metal shop cut and bend some .090 (12ga?) aluminum, these are fairly rigid and I wont have to worry about them flapping in the wind and the 13' drip rail is attached with 16-1 1/4" screws.
I decicdd to fab up some end caps to make the rails even more rigid.
Overall height is 4" including a 1" mounting flange with a 45* bend.
They stick out approximately 1 1/2"-2" over the slides with about 3/8" clearance from the top of the slide frame to bottom of the drip rail when extending and retracting.
Over all they turned out very good and it should solve my water issues.
I ran out of time so I'll paint them white next spring.
  • Thought about doing something like that a few years ago with aluminum trim, but never did it. I need to replace my top seal on my slide and may try to do something like yours, your idea is much better and looks like it came with trailer. Over the years I've looked at rv gutters, but they are very expensive, and look cheesy. You have designed something that is durable and will keep out water. I'm impressed.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 02, 2025
