- OFDPOSExplorer
MagillaGorilla wrote:
Campfire Time wrote:
Black streak remover is the only thing that completely removes them. If you have already waxed you will need to reapply the wax.
After you get rid of them wash your roof, then wash it again before putting it to bed for the winter. That will minimize the black streaks.
Good advise on the roof wash. I had not thought to do that but it make so much sense.
Start off with washing your roof first... THEN start in on the black streaks removal. Polish /buff then a good couple of coats of wax... - MagillaGorillaExplorer
Good advise on the roof wash. I had not thought to do that but it make so much sense. - Campfire_TimeExplorerBlack streak remover is the only thing that completely removes them. If you have already waxed you will need to reapply the wax.
After you get rid of them wash your roof, then wash it again before putting it to bed for the winter. That will minimize the black streaks. - DiskDoctrExplorer
pawpaw47 wrote:
I use LA's Totally Awesome cleaner that I get at the Dollar Tree store. I've tried lots of other cleaners and I haven't found anything that works any better. The best part is that it only costs $1.00.
^^THIS^^^
Spray on, wipe off with clean cloth. Or spray cloth and wipe off.
BEST I've found! - pawpaw47ExplorerI use LA's Totally Awesome cleaner that I get at the Dollar Tree store. I've tried lots of other cleaners and I haven't found anything that works any better. The best part is that it only costs $1.00.
- mattmountz94ExplorerMy wife gave me some H2o cleaning products and I laughed at her. Sure enough I tried it and they came off with ease. Simple pad that you get wet and rub on this clay bar thinger
- LarryJMExplorer IIMy RainKap system stops 100% of black streaks from roof runoff. It also prevents/reduces greatly any black streaks from things like windows or wall fixtures even after 6 to 8 months between normal washings.
Larry - wowens79Explorer IIII bought some Black Streak Remover at Walmart, and they came right off. I thought they were caused by one of the caulks or sealants that are used.
Dick_B wrote:
If you cover the RV there should not be any or many black streaks. IMHO they come from leaves that fill the drain channels on the roof and the runoff stains the walls. The cover keeps the leaves out.
I understand what your saying BUT this advice after the black streaks are already there is like when someone with a sun burn asks for aloe and you say "if you had stayed out of the sun you would not need aloe"
:) - 2012ColemanExplorer II
Looking for advice before your next adventure? Look no further.25,104 PostsLatest Activity: Jan 23, 2025
