Sandy___Shirley's avatar
Sep 03, 2013
Cleaning grey water sensors
Is there a good way to clean the sensors in your waste water grey tanks? My tanks always read full and I’d like to find some type of solution to put in the tanks before we make out next trip so that they slosh around and clean themselves on the way to the next campground. Is there such a thing???
Update Update Update
This is an update made on 9/24. We tried the calgon water softener method with good results. our combined grey tanks are 79 gallons. We added half a bottle of calgon to each grey tank plus 25 gallons of water. We took the RV up for new tires two weeks before our last trip, left the water mix in the tanks and emptied it this past weekend when we got to our campsite.
The shower tank sensors are all working now. Three of the 4 kitchen sensors are also fine now. Plan is to do the same with the kitchen tank before our next trip.
Also, per what we read on line, we will be adding a capfull of calgon to each tank every time we get to a new camsite so the "stuff" does not build up on the sensors again!
  • I've read elsewhere on this board that putting a bag or two of ice in your partially full black tank before traveling can clean off the sensors. I'm not sure about grey tanks, though. I would have problems getting ice into mine.
  • ktmrfs's avatar
    ktmrfs
    Explorer III
    try laundry detergent and some calgon next time you go out. And replace the cheap factory sensors with Horst Miracle Probes. Huge Huge improvement over the factory cheap probes.
  • All that is is a softener that actually will coat your sensors. :R
    Thetford makes a sensor cleaner. I use a bottle of it every other month or so. Can be found at any camping store or at an RV dealership.
    I use an expensive generic quart bottle of lemon cleaner every week. Keeps the sensors clean AND keeps odors down. Publix sells it for a 1.00.
