- Johno02ExplorerSame idea, but I use a grill cleaner spray insteas of oven cleaner. Spray it on good, let it sit for a while, then wash with good pressure on jet-type nozzle. Sometimes repeat if necessary. Wire brush to clean top of grate before each use as it heats up.
- We_Cant_WaitExplorerEasiest way I've found so far it to use Easy Off Oven Cleaner outside, just spray the******out of it. I take the burner out but still spray it down too. Just soak the grate, and housing let it set 1-2 hrs, then use wire brush to clean grate and stiff nylon brush for rest and then hose off good.
- Dog_FolksExplorerTake the burner tube out. One screw and you don't have to fight around it.
- ScottGNomadI hook mine up to a bulk container and run it on high for a couple of hours. Most of the grease is cooked away and you can use a plastic scraper to easily remove the rest.
- 2oldmanExplorer IICar wash...pressure washer. Highest pressure you can get.
I'll always remember one poster's comment on this subject: "You're supposed to clean them?" - downtheroadExplorerIt's a nasty job...
I use:
>a de-greaser like Awesome, Simple Green, whatever I have on hand.
>a putty knife to scrape the heavy stuff out with
>a wire brush
>rags and paper towels
Rinse the whole thing with a low press spray from the hose.
Light it and let it heat up and dry.
A little water does get in the burner tubes, but it cooks itself out after I light the grill.
Looking for advice before your next adventure? Look no further.25,115 PostsLatest Activity: Mar 04, 2025
