life_is_an_open's avatar
May 06, 2014
Coincidence or Can a Brake Controller Activate Truck Brakes?
I have an '09 F150 with a towing package that includes the factory brake controller. I've had no issues with the truck brakes, trailer or the controller since I set everything up three years ago. The truck is driven regularly.
I recently went to pick up my trailer from winter storage. I hitched up, hit the highway and got less than two miles from the storage site when I smelled the distinct odor of burning brakes. (I had not done any heavy braking to that point.) I immediately pulled over thinking that perhaps after long winter storage, a trailer wheel bearing had seized up - or that the trailer brakes were inadvertently being applied! All the drums on the trailer were cold to the touch so I walked up to check out my truck. Its rear drums were cold, the front passenger rotor was warm and the front driver's rotor was painfully hot to the touch!
I had another two miles to my destination so I decided to wait for ten minutes or so and let things cool down. While I waited, I turned the setting down on the controller from 5 to 4. Whether that had any effect on things I don't know but I can tell you that I made it to my destination without any more burning smell present. After maneuvering and unhitching the trailer, I drove the truck back out on the highway and there was no shimmy in the steering wheel or any other behaviour that you'd expect from say a warped rotor, stuck caliper or bad wheel bearing. The brakes feel fine; the truck stops well and doesn't pull to one side.
I did not do another temperature check of the rotors because the burning smell had not resurfaced and I have booked the truck into the garage to have a full brake inspection. I'm just wondering why the brakes acted up only when towing - and seemingly only momentarily. it seems highly improbable but has anyone ever heard of a brake controller triggering the tow vehicle's brakes?!!! Or perhaps the truck has the start of a faulty rotor, caliper or wheel bearing and the added weight of the trailer exacerbated one of these faulty components. At any rate I want to rule out the brake controller or the truck's braking circuit as the culprit.
Thanks in advance for any ideas that you might have.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 15, 2026
