zigzagrv's avatar
zigzagrv
Compartment Door Slam Latches
Is anyone having a problem of the above slam latches breaking and not being able to open the compartment doors? I have had two of my twelve latches that have broken cams, which operate the lock bolt when you lift up on the handle. It is a difficult process to get the doors open, including drilling a hole in the bottom of the assembly and inserting a long, thin screwdriver to push the bolt up to open the door.
There is no name on the latch assembly, other than 'Made in China', to find out who makes them. I did find a picture of a similar latch on the web and it appears to be made (imported?) by AP Products. However, there doesn't seem to be individual parts available for them.
I ended up making a cam from steel (5/32" thick) for the first one that broke, which required a lot of time cutting and grinding it to shape. I have since had a second one break while on the road. This time I used aluminum stock to recreate it.
New latches are available at prices for 40 bucks and up. However, they would have to be painted to match your color.
Now, I have ten more to go. Let me know if anyone else is having a problem with these type latches and if you have found parts for them.
  • I dont slam my doors, instead upon closing I release the latch with my right hand and "knee" the door closed, then release the latch. Never had on break yet.
  • challengerdoor.com they are in Elkhart, IN. Great people, I changed out all my non lockable to lockable with parts from them.
  • ependydad wrote:
    Another who haven't had issues, but since it sounds like replacing them is a pretty big hassle.. can you buy the replacement and then just salvage the parts?
    I'm not willing to pay $40+ to replace a 50 cent part. For the rest of my doors, it would cost me over $400.
  • At first, I thought letting the door slam is what put stress on the cam. After taking it apart and watching it operate, slamming it shut does not involve the cam. The cam only comes into play when using the handle to open it. The cam itself is made from brittle pot metal which breaks at the pivot point.
  • Another who haven't had issues, but since it sounds like replacing them is a pretty big hassle.. can you buy the replacement and then just salvage the parts?
  • Mine have been surprisingly flawless but I'm gentle with them. I never actually "slam" the doors.
  • I had a broken one and found replacements on ebay, inexpensive.
  • I had a slam latch on patio side basement door that did not want to release easily. It was a nuisance, but pulling jiggling, it would release. I noticed door manfs name on inside of door, so gave a call. They said some earlier latches had problems releasing, and sent 2 new ones no charge. New one works great and easy to change out. They sent new keys as well.
    Sorry, can't remember the manufacturers name, and no access to FW now.
    on edit: light bulb just lit...the manuf was challenger door
    Jerry
Looking for advice before your next adventure? Look no further.25,180 PostsLatest Activity: Jan 21, 2026
