valhalla360
Jun 21, 2016Navigator
If you are living in it, I would expect you to be near the max weight (maybe over)rather than the minimum weight (dry).
This isn't a case of being over by 500lbs. You are way over weight.
As stated, 1/2ton and 5th wheel generally doesn't go together.
I would look at a bumper pull in the 20-25' range. That's likely going to maximize living space given the trucks limited capabilities. Or better yet, move up to a 3/4 or 1 ton truck and then lots of options open up.
