JIMNLIN
Jun 22, 2016Explorer III
op wrote:
My question is when considering dry weight does it make a difference if you're pulling a bumper pull or a fifth. I've had opinions on both sides from coworkers. Some say no tow capacity is what it is. Others say yes because the weight distribution is different.
I appreciate any answers you guys have!
Welcome to the forum.
You will get answers from all over the spectrum as some folks don't think a 1/2 ton truck can tow anything and from those that tow with 1/2 ton trucks.
However 1/2 ton trucks can have 8600 GVWR with 6000 lb RAWR down to your size.
You can have more bang for the bucks with small a TT . Check out this 21' 5000 GVWR TT from http://www.allencampermfg.com/upload/201%20FBS%208.30.pdf.
They also have small 5th wheel trailers in the 5k range to look at. Allen has been around for years and their small.
IMO you won't like the V6 towing performance if your planning on road trips. Much depends on how you will use the rig.
