wa8yxm
May 27, 2014Explorer III
The rule I used when I was trailering.
I used wood 2x tire width (Still do) to get to within .75 inches of level (NOTE 2" lumber is 1.5" thick) then I used the jacks for the last little bit.. MOST trailers this should work.
If you want to take a bit of stress off. You could also carry a 1x tire width That gets you to 3/8's of an inch (actually both 3/4 and 3/8 of an inch are close enough to say "Forget it".
Looking for advice before your next adventure? Look no further.25,198 PostsLatest Activity: May 28, 2026
