hmknightnc
May 27, 2014Explorer
wa8yxm wrote:
The rule I used when I was trailering.
I used wood 2x tire width (Still do) to get to within .75 inches of level (NOTE 2" lumber is 1.5" thick) then I used the jacks for the last little bit.. MOST trailers this should work.
If you want to take a bit of stress off. You could also carry a 1x tire width That gets you to 3/8's of an inch (actually both 3/4 and 3/8 of an inch are close enough to say "Forget it".
X2, OP you are way over thinking this. Relax and have some fun
Looking for advice before your next adventure? Look no further.25,198 PostsLatest Activity: May 28, 2026
