TXiceman
May 27, 2014Explorer II
Carry 2 pieces of 2" x? (width of tires) and 2 pieces of 1" to adjust side to side. The large plastic legos only work on firm ground. Soft ground ...you will crack the blocks. Also carry 4 pieces of 3/4 exterior plywood to put under the stabilizers when on soft ground. Also carry a 2" x 6" x 12" long to use under the tongue jack.
From the model trailer you have, they are most likely stabilizer and not jacks. Just run them down to where you are nice and snug. You can use them to make very slight about 1/4" adjustments.
Ken
Ken
Looking for advice before your next adventure? Look no further.25,198 PostsLatest Activity: May 28, 2026
