bronxboy1412's avatar
bronxboy1412
Constant blowouts with tow dolly
We have been using a master tow dolly for 6 years and have experienced numerous blowouts on interstates. I have replaced fenders almost every time, as a blowout breaks the fender away from the body of the tow dolly. Not only does this become dangerous, but frustrating as well. I have tried bias ply, as well as radials and no difference. This always happens at the worst time.
I cannot tow my jeep patriot 4 down but after much aggravation We are thinking of trading cars for four down. I will try one more set of tires which are goodyear and made in america. Beware of chinese tires
  • mowermech wrote:
    Strange...
    I towed a PT Cruiser Convertible on a nearly antique (late'80s/early '90s) DEMCU Kar Kaddy dolly from Billings, MT to Ringgold, GA and back, with no trouble at all. I put new LT Load Range D tires on it before we left, and replaced the shimmy dampener. My speed was between 65 and 70 the entire trip.
    If the OP is putting ST tires on his dolly, I recommend LT, if available in the correct size
    Likely not...I have seen many dollies that use little 14" ST tires.
  • I would look at a new dolly and purchase the tires that they are using. BIL had the same issue years ago and finally found a trailer tire that worked well. Air pressure should be checked frequently.
  • j-d's avatar
    j-d
    Explorer II
    Please post the tire size and load range you're using now. Then the Rim Size (Diameter and Width). Width should be stamped into the rim somewhere.
    I wonder if you could fit larger rims and therefore larger tires.
  • Low tire pressure struck me as a likely culprit, too. There is also the possibility that the dolly alignment is wacko. If the tires toe in or out too much, that could cause problems.
    One other thing occurs to me: might the Patriot's front end weight exceed the capacity of the tires you've been using?
  • Strange...
  • donn0128 wrote:
    What speed do you tow? What is the speed rating of the tires?
    the million $$ question
    bumpy
  • What speed do you tow? What is the speed rating of the tires?
