Hi Phil,
Yup, induction cooking does use less energy than a hot plate. It is a strange system where the induction cooker cycles through three levels to keep the temperature constant. On a kill-a-watt unit set at 220 F once the unit has heated up, the wattage jumps something like 200, 400, 600 then repeats. This happens every few seconds. I have not checked what happens at the highest possible setting.
On the generator, the jumps are enough that in eco mode the engine speed jumps around. This happens even using a Yamaha 3000 sIEB, which surprized me--I thought the boost feature ought to "carry" the induction cooker.
The induction cooker is probably not going to operate on less than a 1000 watt pure sine wave inverter. They will not work at all on modified sine wave according to reports posted on the forums. I was too chicken to try it on msw.
I'm pretty sure that my Nuwave consumes fewer amp-hours than my hotplate to accomplish the same amount of cooking. It is MILES faster than the hotplate.
pnichols wrote:
Don,
If induction plates are so efficient and if one is patient enough, why can't an induction plate be operated at low wattage settings so as to be about equal to a regular hot plate in rate of heating .... while then being quite practical to power them when drycamping with inverters, large battery banks, and solar panels?
Hence, do induction plates used at lower settings make possible drycamp cooking without using one's propane supply?
IAW, you seem to talk them up with regards to being faster .... but how about them also being better misers of precious electrical power?
