wbwood's avatar
wbwood
Cool weather camping
For those of you that dry camp in cooler weather without running the heater, what type of blankets do you use? Do you use sleeping bags?
  • Ok, we are looking at not running the heater or using any type of electric....
  • Usually turn the temp to its lowest setting and crawl in my 25f sleeping bag. That is when I'm by myself, when DW is along, flannel sheets with a very comfy comforter with temp set around 55-60f.
  • We set the thermostat at 60 degrees and we use two comforters. With 100 watts of solar and two battery's we have camped like this for 2 weeks no problems.
  • We frequently dry camp when the low temps hit the 20's or 30's. We use flannel sheets which make a huge difference in sleeping comfort. We run the heater at 65 degrees before we go to bed, then shut it off when we crawl in. I usually get up first and turn the heater back on in the morning before the DW gets up for her coffee.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: May 03, 2023
