Sam_Spade
Jul 09, 2018Explorer
Well there IS a difference....or else they all would just have 30 amp service.
You can get into trouble when just pulling up near the breaker limit without exceeding it.
I got into trouble using my 50 amp service as intended.
Apparently one A/C, the converter and the electric water heater are all on one leg.
With all 3 of those running, one 30 amp breaker on the gen won't hold. On shore power, no problem. WRONG. A connection at the "transfer switch" over heated and the switch control board blew. Since the 50 amp breakers are ganged together, that meant no power at all.
I now have a receptacle for the gen and do the transfer manually. Seems to work fine that way. I think I will not be using the electric element on the water heater much or at all......just incase.
