pianotuna
Jul 09, 2018Nomad III
Hi,
Assuming the load shedder is adjustable amperage. Apparently not all of them are.
After seeing what happens to a brand new female outlet after one season I can understand why the owner doesn't want a 50 amp (really 100 amp) RV plugged into a 30 amp shore power supply.
I do limit myself to 24 amps on a 30 amp supply, but I may add the autoformer if voltage is low. The last two 50 amp shore power supplies I used required the autoformer for me to keep above 107 volts. If I am connected to a 50 amp I set the limit at 30 amps, and my "break out box" does have a 30 amp breaker on one leg (and twin 20 amps on the other leg).
down home wrote:
On board load shedding device will shut one off, otherwise everything may brown out or burn up.
No way can anything on the coach coach 50 amps from a 30 amp circuit.
Looking for advice before your next adventure? Look no further.25,191 PostsLatest Activity: Mar 08, 2025
