Lynnmor
Jul 10, 2018Explorer II
doxiemom11 wrote:
I guess that 30 amp rig running the same size A/C as me uses less power???? They also have a water heater, refrigerator, microwave etc and use those appliances the same as I would, so how do I draw more power by using the same things? .
Since a 50 amp unit might be larger than a 30 amp unit, the A/C might run for a longer period of time. In this case, there would be more A/Cs running at the same time causing a higher load on a loop of like equipped units. As explained in previous threads, you need to look at the entire electrical loop, not just your connection.
Looking for advice before your next adventure? Look no further.25,191 PostsLatest Activity: Mar 08, 2025
