cannesdo
Jan 06, 2017Explorer
Creaking sound on one side when arriving/parking
I repacked my bearings last year (I actually put in all new bearings) and replaced one brake shoe.) Since then, when I pull out of a space -- no problems. On the road...no problems. But a little while after I've slowed and am "taxi'ing" around the park there is this creaking sound whenever I turn left...on the left side of the rig. This last time (only took two trips since then) I came into the park, took one loop around to the left with no sounds, then a second loop at which point it started in. It seems like it happens once everything is warm and loosened up. Left turns at the start of the trip produce no creaking/squealing.
My neighbor suggested I open it up and give the lock nuts another quarter turn or so. They are hand-tight but do you suppose they need to be tightened? or maybe they're too tight? On the first trip it was doing that as I exited a gas station (again turning left)No problem once I got rolling again and the next two stops I parked to the right and no sound then. It's definitely only when turning left. What else could it be? The brakes are working great. Sound good. Feel good.
Lug nuts?
Would just lifting the rig up and trying to wiggle the tire tell me anything? Would it noticeably wiggle if the lock nut wasn't tight enough? What should I look for inside?
Lug nuts?
