lightning_drive's avatar
Nov 26, 2016
Curt 5th wheel hitch Q24 question
New to 5th wheels. Going to a 5th wheel from a cab over and dove tail open trailer.
Here is the situation.
I own a 1999 F550 with pick up bed. Was a ranch truck in AZ. Has a Gooseneck mounted to rails in the bed. I'm working on the purchase of a 39 to 40 foot toy hauler.
I have started looking at the 5th wheel hitches.
Are these rails universal and will I be able to mount the Q24 to the existing rails? Found a used one.
Any thoughts or advice is appreciated as I know nothing about 5th wheels.
I'm a firm believer in over kill when it comes to towing. If 16K is good 24K is better. If F350 Dually is Good F550 is better. Don't want to calculate weight.;)
  • azdryheat wrote:
    What is critical is the placement of the hitch in the truck's bed so that the pin is over the axle. Mixing/matching rails and hitches might throw off where the pin should be.
    AZ
    Same is true of a Gooseneck so rails center over the axle but may not
    Fit the Q24.
    I agree it may be better to buy the entire setup and have it installed by a professional.
    Appreciate your input.
  • What is critical is the placement of the hitch in the truck's bed so that the pin is over the axle. Mixing/matching rails and hitches might throw off where the pin should be.
  • DennisVR wrote:
    I have the same hitch. My thinking was the same as yours. I bought the hitch new and for $30 more went with the Q24, pulling a 18000# 40' toy hauler.
    I had a set of old rails and they didn't fit and had to buy new ones. You could measure the pins on the hitch and the holes on the rails to see if the match. If I remember my old set of rails were quite a ways off.
    Thanks
    Maybe going new hitch and rails is the way to go.
    Mike
  • I have the same hitch. My thinking was the same as yours. I bought the hitch new and for $30 more went with the Q24, pulling a 18000# 40' toy hauler.
