oldschoolhdmike's avatar
Aug 11, 2018
Dicor 551 for trim, it sucks
I bought like 6 tubes to redo my trim and around my front cap on my class c. The original owner used clear silicone on the front cap and it looks horrible. I also have a few crackes/ issues on some of the other spots. I cleaned all the silicone off and used a small bead of dicor 551, then wihtout knowing i tried to smooth it out. well it got everywhere. I cannot run a perfect bead and this got old real quick. it took me longer to clean up my mess that it did to remove the silicone. What can i use that will let me smooth it out? I know you are not suppose to use silocone....but this dicor is not gonna work for me.....
  • lynndiwagon wrote:
    Tape it off with that blue painters tape first then lay the bead. Get a rubber caulk tool at one of the big box stores and use it to smooth out the joint then remove the tape.
    This is exactly how I do it and it ends up looking like a machine did it - perfect.
  • How did you try to smooth it? Sikaflex 221 smooths really well with a finger kept wet with soapy water.
  • Tape it off with that blue painters tape first then lay the bead. Get a rubber caulk tool at one of the big box stores and use it to smooth out the joint then remove the tape.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 14, 2026
