aguablanco
May 29, 2020Explorer
Brockc wrote:
Hello. I need to seal my TT roof. I never used the Dicor cleaner in the past. Just Dawn detergent and water.
The "Dicor System" calls for the part 1 cleaner so the sealant will work correctly, etc..
Should I actually use this, or can I just give it a good cleaning with some detergent and water?
Thanks
I used this product last spring with great success. First, it is imperative to use the cleaner as it also acts as an activator for the sealer. Second, I wrapped the entire trailer with the very thin plastic sheeting as Dicor says the activator/cleaner can stain the sides of the unit. Don't forget to take off the AC shroud, reefer shroud and anything else you don't want the sealer on. After cleaning the roof I removed the plastic immediately. I went around all of the openings with a brush at least twice. Finally rolled the entire roof 3 times with the proper amount of time between coats. Also went around the edge of the roof where I couldn't roll with a brush 2 or 3 times. Took an entire day with almost no help after putting the plastic on. Roof looked great then and still does after ~16 months in the AZ sun. Don't try to cheat, do it once, do it right and move on to something else.
RichH
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 10, 2026
