mowermech
Dec 09, 2014Explorer II
Caveman Charlie wrote:JaxDad wrote:
Mine runs on Jet A exclusively, has since it was new. No smell, no smoke or soot, lights instantly and really throws off heat.
It's also waaaay cheaper than kerosene.
Jet A ??? What is Jet A ? Airplane jet fuel? If so where can you purchase something like that? Thanks.
Most airports will have waste fuel. Maybe they will sell it to the public, maybe not. Some might just give it away. when I worked on turboprop aircraft many years ago, one of the pilots wanted us to save the waste fuel in his personal 5 gallon cans. He used it in his diesel powered Suburban.
The FBO we worked with put their waste fuel in the fuel tanks of their fuel trucks and tugs.
However, before putting any such stuff in a heater where you will be breathing the fumes, it might be a good idea to check the MSDS of what you are using. It just might be that breathing the products of combustion would be unhealthy.
For instance, waste jet fuel from an airport will likely have Prist in it. http://www.chemcas.com/msds112/cas/273/109-86-4_v1.asp
Looking for advice before your next adventure? Look no further.25,202 PostsLatest Activity: Jul 21, 2026
