Caveman_Charlie
Dec 13, 2014Explorer II
dave17352 wrote:Caveman Charlie wrote:eHoefler wrote:Caveman Charlie wrote:JaxDad wrote:
Mine runs on Jet A exclusively, has since it was new. No smell, no smoke or soot, lights instantly and really throws off heat.
It's also waaaay cheaper than kerosene.
Jet A ??? What is Jet A ? Airplane jet fuel? If so where can you purchase something like that? Thanks.
In years past, it was common practice to add gasoline to diesel in the winter months as a anti-gel. 5 gallons of gas to 200-300 gallons of diesel was the average mix.
I'll ask. I've never heard of this.
I have heard of this back in the old days. I would say don't dare do it on the new diesel trucks as it would probably ruin the entire fuel system, from what I have read. With a price tag of about 10k +
Agree on that. The new Tier 3 (I think it's 3) diesels and their computers are way sensitive to things. We have several on them on the farm. They even take there own special oil. As little as a quart of the wrong oil in them will goof them up royally. It's gotten to be a challenge and a pain to make sure you are using the right lubricants in the right places on the right tractors.
The new hydraulic fluid is different to and we have to be somewhat careful of that.
The old days of 80W 90 for universal gear lube are over too. Different equipment requires different lube in there axels and gear boxes these days too.
I don't take chances on fuel or lubricants on this new stuff. I look up what it calls for and I use that. It's gotten so complicated we sometimes have to call the dealer to make sure we are using the right fuel or lubricant for the right equipment. Got bunches of different jugs setting around the farm these days.
We even have one Case IH tractor that takes special brake fluid. We had to have it sent from England when we had a brake fluid leak and after we fixed the leak we found no one in the US had the special fluid. It was a old David Brown number and it was a mineral oil.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
