naturist
Nov 02, 2019Nomad II
Generally speaking, lower tongue weight results in DECREASED directional stability, not increased. Given that you are too heavy for the truck, I’m gonna stick my neck out and suggest the problem is your rear tires are overloaded. Have you tried adding five psi to those tires?
From what you have described, you are right on the edge of stability. If the rear tires are slightly overloaded at whatever pressure you have there, 5 psi would make a world of improvement. If you are already at their max as shown on the sidewalk, you can still add 5 for a brief test, just don’t leave them there or hit any big bumps or potholes. If the added air solves the stability issue, you will know you need higher load range tires. It’s an experiment.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
