Ivylog
Nov 02, 2019Explorer III
Too much tongue weight is a lot better than not enough. I pull a bunch of different trailers without WD but I can adjust the amount of tongue weight by where I tie the load down...more is better. I do not think the 1160 lbs of tongue weight is your problem but you could put a 55 gallon barrel of water in the back to decrease your tongue weight and see if that solves your problem.
I would start by increasing all of your tire pressures to max sidewall (doesn’t cost anything) and see if this helps.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
