Bedlam
Nov 02, 2019Moderator
Are you sure your receiver is rated for that tongue weight? You may need to look into a SuperHitch or equivalent to get that capacity.
Are you using any suspension helpers like air bags? These may be causing more sway and bounce. Look into Timbren, StableLoad or SuperSpring if you need to address sag.
What pressure are you using on your rear tires? Filling them up to maximum side wall listed pressure will help. Some people have better luck running stiffer LT tires on their 1/2 tons, but I don't think you need to add this expense.
You would have had better towing experiences with a SRW 1 or 3/4 ton vehicle, but there is still some things you can do with your current truck to improve on it.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
