Bedlam
Nov 05, 2019Moderator
SGS2019 wrote:Bedlam wrote:
Have you ever taken axle weights of the truck when empty and loaded? Maybe you are unloading the front axle too much which is causing your uneasy towing.
I posted my weights up near the top in this thread. Wish I could upload a picture to make it easier to read.
I should have looked back through the thread a little more carefully. It looks like your front end only loses about 140 lbs when weight distribution is engaged which should not cause a stability issue. Although it goes against the advice some, I typically adjust my weight distribution tension so I get almost all of my front axle weight back. If you plan to drop the hitch height one hole, you may want to increase the hitch head angle more not to only compensate for the additional hitch weight but to also restore more weight up front.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
