SGS2019
Nov 06, 2019Explorer
mkirsch wrote:
I still don't know what your problem *IS* to even make a recommendation. "Tows poorly" is meaningless, and you *are* driving scared even if you don't think so. It's subconscious. You mentioned the accident and how it affected you.
I would gladly make a recommendation, if only there was even a halfway concise description of a problem.
Too much tongue weight isn't your problem, and trying to reduce it with ballast... You'll have over 2000lbs in the back of your trailer before you see an appreciable change in tongue weight. The axles are simply too far back for that to work.
I clearly said that tows poorly is generic; that is admission that I am stating the obvious. What more do I need to describe other than it is difficult to keep in a straight line, feels as if the rear of the truck is not stable, etc. I don’t know what else you are asking to me to describe, so perhaps you could be more specific so we can keep this dialogue constructive.
I have semi decent weight distribution back to my front axle as is, so I don’t think it’s the typical light steering feel when not enough weight is being transferred back to the steer axle.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
