Blanco1's avatar
Blanco1
Dinghy brake options?
I've been looking into this & been upset at the price they cost .
But then today while surfing around I found this!
http://www.readybrake.com/brake-systems.html
Looks awesome & at 1/2 the price of the lower end electric offerings..
I'm seriously considering this option.
What are your thoughts?
Have you used this yourself?
FYI I'm towing with a '97 dodge dually with a large Lance 900 truck camper & the dinghy will be a 2003 Honda CR-V. Auto trans.
Thanks.
I have never dinghy towed before yet have towed MANY different sorts of thing over my life time as a class A truck driver.
  • If you go with ReadyBrute, check with Echarts in Reseda. They set up my CRV, happy with their work. Do have them install charge line w/ wire harness.
    Norm
  • I'm very pleased with my readybrake using my demo tow bar. I'm having the cable attached to my new toad.
  • Blanco, no real need to buy NEW, look at craigs list for your area (I just did) and there are some good prices on tow bars and brake systems in the LA area. I have a SMI brake system that is actually added to the vehicle and is not an in out type. It is a good system and It cam with the rv when we bought it. If you look at rv's on CL look for the baseplates etc, there were some listed in the SD-yuma at a rv wrecking yard. Probaly can get everything cheap, just look around.
  • I was talking with the Tech (who I trust) at the local RV shop, and he said that they install more of the Ready-Brake than anything else in the past couple of years. Price, Ease of Use, and simplicity are all major factors.
    If and when we decide to go with a Toad, it will be the system we use.
  • No at the moment I have no bar or anything yet.
    So I'd be considering buying the whole package from them & end up saving a lot of money!
    I like that's mechanical vs electric as well, less complications.
  • I have the ready brute elite tow bar. Same brake included in the tow bar. Towed with it for about 15,000 miles. Works very well.
    There are several threads on the forum on installing and setting it up.
  • IMO, the Ready Brute Integrated Towbar and Braking System is without doubt the best bang for the buck there is.
    If you already have a towbar that you are happy with, then the Ready Brake System is best for you.
    Note that there is a breakaway system also available. If you are going to go for the braking system, you might as well have the breakaway to go with it!
    At the present time, I do not have one, but if I ever decide that the braking system is something I should have, the Ready Brute/Ready Brake system is the ONLY one I would even consider.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 02, 2025
