The_Falcon's avatar
The_Falcon
Diode lighting disappointing
I’ve been a big fan of new tech stuff, so I have followed and supported diode lighting and its introduction for a lot of years. That is, until I started using the bulbs for the RV, home and flashlights.
These things were supposed to last long, provide acceptable lighting, low heat, and savings on energy.
From my experience, none of these things are true although I’m not sure about the energy savings part because the home bulbs go bad so fast.
Acceptable lighting: Look for yourself compared to others.
Run cool: Check the base of 110 bulb assembly. It will burn your hand and stay hot for a long time after it is turned off.
Long lasting: I’ve had some $25 home light bulbs fail within 10 days and 6 months. I can’t trust them for safety lighting. I bought them from Home Depot. They claim you will save $85 sometime in the future.
Flashlights: I have some for my RV, cars, and home. Unless you check and clean all contacts regularly, they will be dead when you need them most.
Anyhow, I’ll keep using fluorescent and regular RV bulbs when I can.
Joe
Looking for advice before your next adventure? Look no further.25,159 PostsLatest Activity: Aug 24, 2025
