Atlee
Jan 01, 2015Explorer II
Well, you gave the answer. RV's have propane heating systems in order to go off grid, ie boon dock. If you're only going to travel from camp ground to camp ground, you're fine. Or if you're going to deploy generators everywhere you stop, you're fine.
You turned your TT into a room to live in while your house was being built. It's a single purpose unit now, and there is nothing wrong with that. However, do you every plan to sell it? For me, it's now unbuyable. I wouldn't even look at a RV that didn't have a propane system in it.
Stuka wrote:
I picked up a 30 Springdale to use as a temp home while my house is being built. I pulled out the wall between the dining area and the queen bedroom, removed the bed and small couch, to make an open living area. There was a propane furnace on the floor, pretty much right in the way, so I removed that too and covered the holes, then tiled over it. I put in a simple 1500 watt electric floor heater and after a couple nights of 38 degrees, it seems to do the trick. Why do trailers use the propane heaters? Is it in case there is no electricity available and they can heat off the propane bottles? It seems like a lot of complication (blowers, vents, ducting) when a single electric heater does the job as well.
Looking for advice before your next adventure? Look no further.25,191 PostsLatest Activity: Apr 05, 2026
