MitchF150
May 23, 2020Nomad
If it's the same as the F150's "sway control", then NO, it's not a substitute for a hitch WD/sway control device...
In my F150's case, it only comes into play when your truck really, really starts to sway.. Like see sawing the steering wheel kind of sway.
You will need at the minimum a WD hitch just to help level you out and put some weight back to your front axle.
Good luck! Mitch
Good luck! Mitch
Looking for advice before your next adventure? Look no further.25,197 PostsLatest Activity: May 23, 2026
