MrWizard
Mar 10, 2017Moderator
Look up poor man's trimetric thread on this sites Tech Issues forum
Just under $40
Measures volts, amps charge and discharge, and shows percent of battery charge level and amp hrs left in the bank, even watts charge or discharge
All at the push of a button
If all you want is voltage , there lots of $10 meters
If you want to measure how much power you are using you need an amp meter
Any thing much over 10 amps usually need an external sensor
Either a shunt or "hall effect named sensor coil"
Just under $40
Looking for advice before your next adventure? Look no further.25,191 PostsLatest Activity: Apr 04, 2026
