MrWizard
Mar 11, 2017Moderator
Missing something, yeah a whole lot
That plug in will give you volts on that circuit, not volts at the battery
And that's all
The meter I mentioned gives the amps load, or the amps charging (IF charging)
Among with a lot more
If all you ever do is go some place where you plug into shore power, then that volt meter will let you know that your converter is working
If you want to dry camp for more than one night, you will be better informed knowing what's going on with your batteries and how much power you use
And accurately guage your generator run recharge time
And that's all
Looking for advice before your next adventure? Look no further.25,191 PostsLatest Activity: Apr 04, 2026
