time2roll wrote:
SCVJeff wrote:
Probably not needed, but the problem with just a voltmeter is that you need to measure things at rest to reflect the charts mentioned above. Once I got used to and confident in my SOC readings, that's now all I use
The chart that shows 10.5 volts as dead is actually while the battery in under moderate load.
Kinda get used to it. Monitor is accurate within maybe 5 percent and the voltmeter probably 10 percent. The 10 percent is fine for most usage IMO.
Yeah but
getting there is where the SOC comes in handy. Its looking at voltage, current, and matches it against charging history, battery capacity (a config item), and has a rough idea where "dead" is based on aggregated AH draw throughout the discharge. 10.5 may be dead at 180A draw for late night popcorn, but what did you pull out of the remaining cap once you're back down to a 15A load and the battery recovers given the current state of the batteries, age, etc? I bought the BMK module for the Magnum because I wanted significantly better resolution for V&C; how I did it before the SOC calculation. Not needed but its a wonderful thing.
