MrVan
Nov 10, 2013Explorer
If you use enough leveling blocks or adequately long boards you can still chock both sides. The chocks then set on a leveling block at the same height as the tire. I have found that using the TV to tighten up the front axle chocks by pulling against them while inserting two rear axle chocks up tight is almost as good as putting the wedge between the tires on each side.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 19, 2026
