MrWizard
Jan 03, 2016Moderator
does anbody remember this "Heater" (found the patent)
sorry no picture, i can't find one online ( see page 2 found the patent application and drawings )
i have searched and searched, vintage old portable
you name it, i tried it
it is/was 120v portable, not quartz or halogen or oil or ceramic
it was sealed partial vacuum low pressure steam
DE-iozined water sealed under partial vacuum , when the heat was turned on the water evaporated aka turned to steam at a much lower temperature, heating the surface of the heater much like oil filled
only doing it faster, it would make "ticking" noises while warming up
it was taller than it was wide (did NOT look like a radiator)
looking at the front, it was "V" shaped to provide more surface area
there was temp control knob and on-off switch
the surface temp was really warm but NOT hot, you could touch it with out getting burned, you could hold tissue or fabric against it, it would not catch fire, not hot enough to make anything smolder
there was a fan that came on-off with the temp of the heater
this was the late 80's to 92
i have not seen one in many years, can not find one on ebay
can not find any images or info using google
my memory says the brand was "Heat Tec" but a search brings all kinds of stuff .. not related to what i'm looking for
maybe one of you have or had one ?
i bought it at "FedCo" which is now defunct
