BarneyS
Nov 03, 2015Nomad
It is fine that you drained the stuff out after winterizing. It will reduce the tendency to leave a "taste" in the water when you use it next summer. Make sure you fill and empty your fresh water tank and water heater several times before you use the unit to get all the antifreeze residue out. The water heater will foam badly until all of it is removed.
Barney
Barney
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 10, 2026
